RT9266B pdf datasheet (Peak 3A
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-12
479461
分享资料个
The RT9266B is a compact, high efficiency, and low
voltage step-up DC/DC converter with an Adaptive
Current Mode PWM control loop, includes an error
amplifier, ramp generator, comparator, switch pass
element and driver in which providing a stable and high
efficient operation over a wide range of load currents. It
operates in stable waveforms without external
compensation.
The low start-up input voltage below 1V makes RT9266B
suitable for 1 to 4 battery cells applications with a 500mA
internal switch. The 550kHz high switching rate minimized
the size of external components. Besides, the 25μA low
quiescent current together with high efficiency maintains
long battery lifetime.
评论(0)
发评论
下载排行榜
