MAX6615, MAX6616 pdf datasheet
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-18
李鸿洋
分享资料个
The MAX6615/MAX6616 monitor two temperature chan-
nels, either the internal die temperature and the temper-
ature of an external thermistor, or the temperatures of
two external thermistors. The temperature data controls
a PWM output signal to adjust the speed of a cooling
fan, thereby minimizing noise when the system is run-
ning cool, but providing maximum cooling when power
dissipation increases. The fans’ tachometer output sig-
nals are monitored by the MAX6615/MAX6616 to detect
fan failure. If a fan failure is detected, the FAN_FAIL
output is asserted.
评论(0)
发评论
下载排行榜
