CA3083 pdf datasheet(General P
消耗积分:2 | 格式:rar | 大小:147 | 2008-12-21
时见栖鸦
分享资料个
The CA3083 is a versatile array of five high current (to
100mA) NPN transistors on a common monolithic substrate.
In addition, two of these transistors (Q1 and Q2) are
matched at low current (i.e., 1mA) for applications in which
offset parameters are of special importance.
Independent connections for each transistor plus a separate
terminal for the substrate permit maximum flexibility in circuit
design.
评论(0)
发评论
下载排行榜
