CA3162 pdf datasheet(A/D Conve
消耗积分:3 | 格式:rar | 大小:581 | 2008-12-21
分享资料个
Features
• Dual Slope A/D Conversion
• Multiplexed BCD Display
• Ultra Stable Internal Band Gap Voltage Reference
• Capable of Reading 99mV Below Ground with Single
Supply
• Differential Input
• Internal Timing - No External Clock Required
• Choice of Low Speed (4Hz) or High Speed (96Hz)
Conversion Rate
• “Hold” Inhibits Conversion but Maintains Delay
• Overrange Indication
- “EEE” for Reading Greater than +999mV, “-” for
Reading More Negative than -99mV When Used
With CA3161E
评论(0)
发评论
下载排行榜
