HS-4423RH, HS-4423BRH pdf data
消耗积分:3 | 格式:rar | 大小:59 | 2008-12-23
刘芳
分享资料个
The Radiation Hardened HS-4423RH and the HS-4423BRH
are inverting, dual, monolithic high-speed MOSFET drivers
designed to convert TTL level signals into high current
outputs at voltages up to 18V.
The inputs of these devices are TTL compatible and can be
directly driven by our HS-1825ARH PWM device or by our
ACS/ACTS and HCS/HCTS type logic devices. The fast rise
times and high current outputs allow very quick control of
high gate capacitance power MOSFETs, like our Rad Hard
FS055, in high frequency applications.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
