X80140, X80141, X80142, X80143
消耗积分:3 | 格式:rar | 大小:341 | 2008-12-23
张燕
分享资料个
Voltage Supervisor/Sequencer Quad Programmable Time Delay with Local/Remote Voltage Monitors
The X80140 is a voltage supervisor/sequencer with four built
in voltage monitors. This allows the designer to monitor up to
four voltages and sequence up to five events.
Low voltage detection circuitry protects the system from
power supply failure or “brown out” conditions, resetting the
system and resequencing the voltages when any of the
monitored inputs fall below the minimum threshold level. The
RESET pin is active until all monitored voltages reach proper
operating levels and stabilize for a selectable period of time.
Five common low voltage combinations are available,
however, Intersil’s unique circuits allow the any voltage
monitor threshold to be reprogrammed for special needs or
for applications requiring higher precision.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
