基于AS5311-TS_EK_AB磁性传感器的参考设计
消耗积分:2 | 格式:pdf | 大小:43.63KB | 2021-01-09
84784
分享资料个
说明
  • AS5311-TS_EK_AB, Demo Board for the AS5311 is a contactless high resolution magnetic linear encoder for accurate linear motion and off-axis rotary sensing with a resolution down to <0.5um. It is a system-on-chip, combining integrated Hall elements, analog front end and digital signal processing on a single chip, packaged in a small 20-pin TSSOP package. A multipole magnetic strip or ring with a pole length of 1.0mm is required to sense the rotational or linear motion
评论(0)
发评论
下载排行榜
