HC-5509B pdf datasheet(ITU CO/
消耗积分:2 | 格式:rar | 大小:225 | 2009-01-06
kmno4
分享资料个
The HC-5509B telephone Subscriber Line Interface Circuit integrates most of the BORSCHT functions on a monolithic IC. The device is manufactured in a Dielectric Isolation (DI) process and is designed for use as a high voltage interface between the traditional telephone subscriber pair (Tip and Ring) and the low voltage filtering and coding/decoding functions of the line card. Together with a secondary protection diode bridge and “feed” resistors, the device will withstand 1000V lightning induced surges, in plastic packages. The SLIC also maintains specified transmission performance in the presence of externally induced longitudinal currents. The BORSCHT functions that the SLIC provides are:
Battery Feed with Subscriber Loop Current Limiting
•Overvoltage Protection
•Ring Relay Driver
•Supervisory Signaling Functions
•Hybrid Functions (with External Op Amp)
•Test (or Battery Reversal) Relay Driver
In addition, the SLIC provides selective denial of power to subscriber loops, a programmable subscriber loop current limit from 20mA to 60mA, a thermal shutdown with an alarm output and line fault protection. Switch hook detection, ring trip detection and ground key detection functions are also incorporated in the SLIC device.
The HC-5509B SLIC is ideally suited for line card designs in PBX and CO systems, replacing traditional transformer solutions.
评论(0)
发评论
下载排行榜
