HA-5170 pdf datasheet (8MHz, P
消耗积分:3 | 格式:rar | 大小:332 | 2009-01-07
王尚岱
分享资料个
The Intersil HA-5170 is a precision, JFET input, operational
amplifier which features low noise, low offset voltage and
low offset voltage drift. Constructed using FET/Bipolar
technology, the Intersil Dielectric Isolation (DI) process, and
laser trimming this amplifier offers low input bias and offset
currents. This operational amplifier design also completely
eliminates the troublesome errors due to warm-up drift.
Complementing these excellent input characteristics are
dynamic performance characteristics never before available
from precision operational amplifiers. An 8V/μs slew rate and
8MHz bandwidth allow the designer to extend precision
instrumentation applications in both speed and bandwidth.
These characteristics make the HA-5170 well suited for
precision integrator amplifier designs.
The superior input characteristics also make the HA-5170
ideally suited for transducer signal amplifiers, precision
voltage followers and precision data acquisition systems.
For application assistance, please refer to Application Note
AN540 addressing specifically this device.
评论(0)
发评论
下载排行榜
