HS-65647RH pdf datasheet (Radi
消耗积分:3 | 格式:rar | 大小:333 | 2009-01-08
张艳
分享资料个
The Intersil HS-65647RH is a fully asynchronous 8K x 8
radiation hardened static RAM. This RAM is fabricated using
the Intersil 1.2 micron silicon-on-sapphire CMOS technology.
This technology gives exceptional hardness to all types of
radiation, including neutron fluence, total ionizing dose, high
intensity ionizing dose rates, and cosmic rays.
Low power operation is provided by a fully static design. Low
standby power can be achieved without pull-up resistors,
due to the gated input buffer design.
Specifications for Rad Hard QML devices are controlled
by the Defense Supply Center in Columbus (DSCC). The
SMD numbers listed here must be used when ordering.
Detailed Electrical Specifications for these devices are
contained in SMD 5962-95823. A “hot-link” is provided
on our homepage for downloading.
评论(0)
发评论
下载排行榜
