ISL90841 pdf datasheet (Quad D
消耗积分:2 | 格式:rar | 大小:433 | 2009-01-10
王敏
分享资料个
Low Noise, Low Power I2C® Bus, 256 Taps
The ISL90841 integrates four digitally controlled
potentiometers (XDCP) on a monolithic CMOS integrated
circuit.
The digitally controlled potentiometers are implemented with
a combination of resistor elements and CMOS switches. The
position of the wipers are controlled by the user through the
I2C bus interface. Each potentiometer has an associated
Wiper Register (WR) that can be directly written to and read
by the user. The contents of the WR controls the position of
the wiper.
All four potentiometers have one terminal tied to GND. The
DCPs can be used as a resistor divider or as two-terminal
variable resistors in a wide variety of applications including
control, parameter adjustments, and signal processing.
评论(0)
发评论
下载排行榜
