CN0416-用户指南Wiki
消耗积分:3 | 格式:pdf | 大小:444.24KB | 2021-03-23
张亮
分享资料个
This version (03 Jan 2021 21:57) was approved by Robin Getz.The Previously approved version (17 Jul 2019 01:26) is available.Diff
EVAL-CN0416-ARDZ Shield Overview
CN0416 is an isolated and non-isolated RS-485 transceiver board which allows easy implementation of asynchronous serial (UART) data transmission between multiple Arduino form factor systems or nodes, especially over long distances. The circuit uses the ADM2682E RS-485 transceiver for isolated communications and the LTC2865 for non-isolated RS-485 communications. Both can be configured to either full-duplex or half duplex operation and with open or terminated transmission lines. The circuit has on-board RJ-45 ports which allows the use of the common CAT5 cable for fast physical wiring of nodes. The termination resistance is catered by default to the CAT5 cable characteristic impedance of 100 ohms but can be configured to support the standard RS485 cable impedance of 120 ohms. The cable also carries power supply lines which are by default unpowered but can be connected to a 3.3V supply from the board's low-dropout voltage regulator, ADP7102. The system has an on-board 10-pin connector compatible with the ADALM-UARTJTAG which allows for serial connections to a PC or other device.
The ADM2682E is capable of a data rate up to 16 Mbps and has true fail-safe receiver inputs with adjusted differential voltage threshold. It provides 5 kV signal isolation using the iCoupler data channel and 5 kV power isolation using the isoPower integrated dc-to-dc converter.
The LTC2865 is capable of a data rate up to 20 Mbps and has full fail-safe receiver inputs. An internal window comparator determines the fail-safe condition without the need to adjust the differential input voltage thresholds.
RS-485 Communications
CN0416 can be configured to different settings and operations of the RS-485 communication standard using multiple on-board physical switches. There are three different switches to be configured for both isolated and non-isolated operations as shown below:
The switches shown in the image above provide the following functions.
Switch Function
S1 Configures Address of RS-485 Node
S2 Selects Isolated vs non-Isolated Part and Half/Full Duplex Mode
S4 Selects Physical Layer Half/Full Duplex Mode of non-Isolated LTC2865
S5 Selects Physical Layer Half/Full Duplex Mode of Isolated ADM2682E
S6 Selects Termination Resistance of non-Isolated LTC2865
S7 Selects Termination Resistance of Isolated ADM2682E
Summary of Switch Configurations
In summary, all switch positions for the configurable settings of the CN0416 in RS-485 communications are shown below. (Switch positions that do not matter for a setting are NA)
RS-485 Configuration Switch Positions
S2 S4 S5 S6 S7
Isolated, Full Duplex, and Terminated 2 NA 2 NA 2
Isolated, Full Duplex, and Open 2 NA 2 NA 1
Isolated, Half Duplex, and Terminated 1 NA 1 NA 2
Isolated, Half Duplex, and Open 1 NA 1 NA 1
Non-Isolated, Full Duplex, and Terminated 3 2 NA 2 NA
Non-isolated, Full Duplex, and Open 3 2 NA 1 NA
Non-isolated, Half Duplex, and Terminated 4 1 NA 2 NA
Non-isolated, Half Duplex, and Open 4 1 NA 1 NA
Isolated vs Non-Isolated RS-485 Operation
CN0416 can be configured to use either the ADM2682E or the LTC2865 for Half/Full Duplex RS-485 transmission. The difference between the part selected is that the ADM2682E provides complete signal and power isolation, where as the LTC2865 does not isolate the standard RS-485 transmission.
Switch S2 Position Duplex Mode Operation Part Used
Position 1 HALF Duplex (Isolated) Signal and Power Isolated RS-485 ADM2682E
Position 2 FULL Duplex (Isolated) Signal and Power Isolated RS-485 ADM2682E
Position 3 HALF Duplex (Non-Isolated) Non-Isolated RS-485 LTC2865
Position 4 FULL Duplex (Non-Isolated) Non-Isolated RS-485 LTC2865
Full Duplex or Half Duplex Operation
CN0416 can be configured to either full-duplex operation or half-duplex operation depending on the application. Switch S4 and S5 controls this setting with the differential RS-485 lines, and switch S2 controls the driver and receiver Enable.
Mode Operation Switch Position Requirements
Isolated Half-Duplex RS-485 S5 = Position 1 (HALF) & S2 = Position 1 (HALF ISO)
Full-Duplex RS-485 S5 = Position 2 (FULL) & S2 = Position 2 (FULL ISO)
Non-Isolated Full-Duplex RS-485 S4 = Position 2 (FULL) & S2 = Position 3 (FULL NON_ISO)
Half-Duplex RS-485 S4 = Position 1 (HALF) & S2 = Position 4 (HALF NON_ISO)
  • When S4 and S5 are in switch position 1, S2 MUST be placed in switch position 1 or 4, depending on the part you are using.
  • When S4 and S5 are in switch position 2, S2 MUST be placed in switch position 2 or 3, depending on the part you are using.
Cable Length and Termination Selection
The data rate of RS-485 communications varies with the cable length. Below is a figure showing the relationship of data rate and cable length.
The type of termination also depends on the cable length as well as the cable characteristic impedance. The ordinary CAT5/CAT5E cable has a characteristic impedance of 100 ohms while the RS-485 standard cable has 120 ohms.
By default, the parallel termination resistance is 100 ohms which supports CAT5/CATE cables. But, this can be reconfigured to 120 ohms by disconnecting solder jumpers JP4, JP6, JP8 and, JP10 and shorting solder jumpers JP3, JP5, JP7, JP9.
Switch S6 and S7 controls the type of termination of the RS-485 lines.
Mode Switch S6 and S7 Position Termination Type
Isolated S7 = Position 1 (OPEN) No Line Termination
S7 = Position 2 (TERM) Parallel Resistance Termination
Non-Isolated S6 = Position 1 (OPEN) No Line Termination
S6 = Position 2 (TERM) Parallel Resistance Termination
  • When S6 and S7 are in switch position 1, there is no RS-485 termination. This is suitable for low-power, short transmissions over a total distance less than 0.78 m.
  • When S6 and S7 are in switch position 2, a parallel resistance termination is inserted. This is suitable for long distance, high power transmissions not exceeding a total distance of 4000 ft.
Hex Switch Addressing
The hex switch can be used to easily setup node addressing when the CN0416 is connected to a microcontroller via the Arduino headers. Bits are connected to analog inputs A0-A3 by default, which can be read as digital inputs by most Arduino platforms. Alternative bit mapping can be selected by resistor-stuff options on the CN0416, shown in parentheses. The bit values of the gpio pins used in node addressing are shown below.
GPIO / Arduino Pin Connection
S1 Hex Switch Position AIN0 (D7) AIN1 (D6) AIN2 (D5) AIN3 (D4)
0 Low Low Low Low
1 Low Low Low High
2 Low Low High Low
3 Low Low High High
4 Low High Low Low
5 Low High Low High
6 Low High High Low
7 Low High High High
8 High Low Low Low
9 High Low Low High
A High Low High Low
B High Low High High
C High High Low Low
D High High Low High
E High High High Low
F High High High High
RJ-45 Connection and Wiring Multi-Node Systems
The CN0416 has four RJ-45 ports, P4 and P5 for isolated communications and P6 and P24 for non-isolated communications. Each pair has a cross-over connection with each other. This facilitates the use of either a straight-through or crossover CAT5 cable.
With a straight-through connection, the CAT5 cable should connect two boards using the same port, e.g. (P4 of a master node is connected to P4 of a slave node in isolated communications).
With a crossover connection, the CAT5 cable should connect two boards using opposite ports, e.g. (P6 of a master node is connected to P24 of a slave node in non-isolated communications).
Below shows illustrations of connecting multiple nodes using either a straight-through or a crossover cable for both isolated and non-isolated communications.
For Isolated Communications:
For Non-Isolated Communications
ADALM-UARTJTAG Connection
The CN0416 has a 10 pin 5×2 connector to interface with an ADALM-UARTJTAG. The yellow LED DS2 will indicate a live connection between the two devices.
For half duplex set-ups, the ADALM-UARTJTAG needs to be setup for RS485 communications.
Schematic, PCB Layout, Bill of Materials
EVAL-CN0416-ARDZ Design & Integration Files
  • Schematics
  • PCB Layout
  • Bill of Materials
  • Allegro Project
End of Document
评论(0)
发评论
下载排行榜
