ISL12022 pdf datasheet (Low Po
消耗积分:3 | 格式:rar | 大小:333 | 2009-01-19
王杰
分享资料个
and Embedded Temp Compensation ±5ppm with Auto Daylight Saving
The ISL12022 device is a low power real time clock with an
embedded Temp sensor for oscillator compensation,
clock/calendar, power fail, low battery monitor, brownout
indicator, single periodic or polled alarms, intelligent
battery-backup switching, Battery Reseal™ function and 128
bytes of battery-backed user SRAM.
The oscillator uses an external, low-cost 32.768kHz crystal.
The real time clock tracks time with separate registers for
hours, minutes, and seconds. The device has calendar
registers for date, month, year and day of the week. The
calendar is accurate through 2099, with automatic leap year
correction.
Daylight Savings time adjustment is done automatically,
using parameters entered by the user. Power fail and battery
monitors offer user-selectable trip levels. A time stamp
function records the time and date of switchover from VDD to
VBAT power, and also from VBAT to VDD power.
评论(0)
发评论
下载排行榜
