MAX16003, MAX16004, MAX16005 p
消耗积分:0 | 格式:rar | 大小:335 | 2009-01-22
分享资料个
The MAX16000–MAX16007 are low-voltage, quad-/hex-/
octal-voltage μP supervisors in small thin QFN and TSSOP
packages. These devices provide supervisory functions for
complex multivoltage systems. The MAX16000/
MAX16001/MAX16002 monitor four voltages, the
MAX16003/MAX16004/MAX16005 monitor six voltages,
and the MAX16006/MAX16007 monitor eight voltages.
The MAX16000/MAX16001/MAX16003/MAX16004/
MAX16006 offer independent outputs for each monitored
voltage. The MAX16001/MAX16002/MAX16004–
MAX16007 offer a reset output that asserts whenever
any of the monitored voltages fall below their respective
thresholds or the manual reset input is asserted. The
reset output remains asserted for the reset timeout after
all voltages are above their respective thresholds and
the manual reset input is deasserted. The minimum
reset timeout is internally set to 140ms or can be adjusted
with an external capacitor.
All open-drain outputs have internal 30μA pullups that
eliminate the need for external pullup resistors.
However, each output can be driven with an external
voltage up to 5.5V. Other features offered include a
manual reset input, a tolerance pin for selecting 5% or
10% input thresholds, and a margin enable function for
deasserting the outputs during margin testing.
The MAX16001/MAX16002/MAX16004–MAX16007 offer
a watchdog timer that asserts RESET or an independent
watchdog output (MAX16005) when the watchdog
timeout period (1.6s typ) is exceeded. The watchdog
timer can be disabled by floating the input.
评论(0)
发评论
下载排行榜
