The MAX19505 dual-channel, analog-to-digital converter(ADC) provides 8-bit resolution and a maximum sample rate of 65Msps.The MAX19505 analog input accepts a wide 0.4V to 1.4V input common-mode voltage range, allowing DCcoupled inputs for a wide range of RF, IF, and baseband front-end components. The MAX19505 provides excellent dynamic performance from baseband to high input frequencies beyond 400MHz, making the device ideal for zero-intermediate frequency (ZIF) and highintermediate frequency (IF) sampling applications. The typical signal-to-noise ratio (SNR) performance is 49.8dBFS and typical spurious-free dynamic range (SFDR) is 69dBc at fIN = 70MHz and fCLK = 65MHz. The MAX19505 operates from a 1.8V supply. Additionally, an integrated, self-sensing voltage regulator allows operation from a 2.5V to 3.3V supply (AVDD). The digital output drivers operate on an independent supply voltage (OVDD) over the 1.8V to 3.5V range.The analog power consumption is only 43mW per channel at VAVDD = 1.8V. In addition to low operating power, the MAX19505 consumes only 1mW in powerdown mode and 15mW in standby mode.
