基于LT1117_Typical Application直流到直流单输出电源的参考设计
消耗积分:2 | 格式:pdf | 大小:188.56KB | 2021-07-14
分享资料个
说明
  • Typical Application for LT1117CM Adjusting Output Voltage of Fixed Regulator. The LT1117 is a positive low dropout regulator designed to provide up to 800mA of output current. The device is available in an adjustable version and fixed output voltages of 2.85V, 3.3V and 5V. All internal circuitry is designed to operate down to 1V input to output differential. Dropout voltage is guaranteed at a maximum of 1.2V at 800mA, decreasing at lower load currents
主要特色
  • Conversion Type
    DC to DC
  • Input Voltage
    12 V
  • Output Current
    0.8 A
  • Topology
    LDO
评论(0)
发评论
下载排行榜
