用ADSP-2191设计的雷达脉压系统控制单元
消耗积分:5 | 格式:rar | 大小:223 | 2009-02-27
分享资料个
详细介绍了利用ADI公司的16位定点数字信号处理器ADSP-2191强大的串行外部接口,结合CPLD的功能拓展和控制,成功完成了某雷达脉冲压缩系统控制单元的设计,并实现了用主机控制多达6块的脉冲压缩处理板的功能,且可以完全由主机控制每块脉压处理板进行相应的脉冲压缩及故障上报。由于其速度快、成本低、可编程能力强,可广泛应用于各种需要复杂控制和实时通信的领域。
关 键 词 脉冲压缩; 数字信号处理器; 可编程逻辑器件; 串口通信
Abstract In this paper it is introduced in detail that radar pulse compression system control unit is successfully designed by using the powerful serial peripheral interface of ADI’s fixed-point 16-bit digital signal processor ADSP-2191 and combining the CPLD function expansion and control. It has realized to control six pulse compression board with host computer. Furthermore, it can also control each board to process corresponding compression pulse and report the board fault status to host computer. Owing to the fast speed, low cost, powerful programmable capability, it can be widely applied to require all kind of complicated control and real time communication area.
Key words pulse compression; DSP; CPLD; serial port communication
评论(0)
发评论
下载排行榜
