DS3600 pdf datasheet (Secure S
消耗积分:10 | 格式:rar | 大小:322 | 2009-03-02
张文
分享资料个
The DS3600 is a secure supervisor with 64 bytes of SRAM for applications requiring the secure storage of encryption keys, including POS terminals. The DS3600 supports the highest security level of the FIPS 140-2, Common Criteria, PCI-PED, and EMV 4.1 certification entities. The 64B key memory is constantly complemented in the background to prevent oxide stress and memory imprinting. In the event of a qualified tamper event, the key memory is rapidly cleared and a negative bias is applied to clear SRAM external to the DS3600.
64字节无痕迹、可快速擦除的密钥存储器
一旦检测到篡改动作时,可迅速清除外部SRAM
带有闰年补偿的RTC有效期至2100
看门狗定时器
CPU监控电路
4个通用防篡改比较器具有关联参考
防篡改逻辑输入
维护和状态选择逻辑输入
内置温度传感器,具有温度变化率检测
片内随机数发生器
篡改事件闭锁和时间标记
XTAL振荡器用于支持篡改检测
低功耗
3线串行接口
无外部暴露引脚的BGA封装
通过美国保险商实验室协会(UL®)认证
评论(0)
发评论
下载排行榜
