These new antennas compliment Mobile Mark's 2.4GHz antenna product line with a new mounting option. These body mount style antennas can be mounted to any vehicle, container or bulkhead. The rugged style is excellent for industrial applications, yet attractive for consumer use. The designs use a 16mm (0.625”) feed through for securing to the vehicle. Access to the underside of the body surface is required to complete the installation. The antennas are outfitted with 30cm (1 foot) of RF-195 cable and TNC male connector. Jumper cables for completing the installation are supplied separately and use RF-195 low loss cable. Alternatively, a longer integral cable can be supplied upon request. Antenna performance is 2.5dBi (max) for the ELRM3 Series and 2.0dBi (max) for the ELDM Series, with no ground plane required for proper operation. The antennas can even be mounted on fibreglass or plastic housing and meet specifications.
