彩显电源管大功率场效应管技术参数与代换
消耗积分:10 | 格式:exe | 大小:10.9 MB | 2011-02-09
分享资料个
转 到  “彩  显  电  源  电  路 图  列  表”
型号 VDSS (V)  RDS(ON) (R)  ID (A)  PD  (W)  封装形式  代换型号  备 注 生产厂商
2N7000   60   5   0.2   0.4  TO-92       Fairchild
2N7002   60   7.5   0.115  0.2  SOT-23       Fairchild
2SJ377   -60   0.19   -5     POWER MOLD   2SJ377   A  Toshiba
2SJ378   -60   0.19   -5     TPS   2SJ378   A  Toshiba
2SJ380   -100   0.21   -12    TO-220IS  2SJ380   A  Toshiba
2SJ401   -60   0.045   -20     TO-220FL/SM   2SJ401   A  Toshiba
2SJ402   -60   0.038   -30     TO-220FL/SM   2SJ402   A  Toshiba
2SJ407   -200   1   -6     TO-220IS   2SJ407   A Toshiba
2SJ412   -100   0.21   -16     TO-220FL/SM   2SJ412   A  Toshiba
2SJ419   -12   0.082   -4     SOP-8(单)       Sanyo
2SJ420   -12   0.063   -5     SOP-8(单)       Sanyo
2SJ421   -30   0.058   -5     SOP-8(单)   TPC8104-H  A  Sanyo
2SJ438   -60   0.19   -5     TO-220IS   2SJ438   A Toshiba
2SJ439   -16   0.2   -5     POWER MOLD   2SJ439   A  Toshiba
2SJ464   -100   0.09   -18    TO-220IS  2SJ464   A  Toshiba
2SJ465   -16   0.71   -2     POWER-MINI   2SJ465   A  Toshiba
2SJ468   -30   0.1   -4     SOP-8(单)   TPC8104-H  A  Sanyo
2SJ469   -30   0.075   -5     SOP-8(单)   TPC8104-H  A  Sanyo
2SJ482   -60   0.19   -5      SP   2SJ482   A  Toshiba
2SJ507   -60   0.7   -1     TO-92MOD   2SJ507   A Toshiba
2SJ508   -100   1.9   -1     POWER-MINI   2SJ508   A  Toshiba
2SJ509   -100   1.9   -1     TO-92MOD   2SJ509   A  Toshiba
2SJ511   -30   0.45   -2     POWER-MINI   2SJ511   A  Toshiba
2SJ512   -250   1.25   -5    TO-220IS  2SJ512   A  Toshiba
2SJ513   -200   0.5   -9.5    TO-220IS  2SJ513   A  Toshiba
2SJ514   -250   0.625   -7.5    TO-220IS  2SJ514   A  Toshiba
2SJ515   -200   0.64   -7    TO-220IS  2SJ515   A  Toshiba
2SJ516   -250   0.8   -6.5    TO-220IS  2SJ516   A  Toshiba
2SJ525   -30   0.12   -5     TPS   2SJ525   A  Toshiba
2SJ537   -50   0.19   -5     TO-92MOD   2SJ537   A  Toshiba
2SK1119   1000   3.8   4     TO-220AB   2SK1119   A  Toshiba
2SK1120   1000   1.8   8     TO-3P(N)   2SK1120   A  Toshiba
2SK1359   1000   3.8   5     TO-3P(N)   2SK1359   A  Toshiba
2SK1365   1000   1.8   7     TO-3P(N)IS   2SK1365   A  Toshiba
2SK1489   1000   1   12     TO-3P(L)   2SK1489   A  Toshiba
2SK1930   1000   3.8   4     TO-220FL/SM   2SK1930   A  Toshiba
2SK2173   60   0.017   50     TO-3P(N)   2SK2173   A  Toshiba
2SK2200   100   0.35   3     TPS   2SK2200   A  Toshiba
2SK2201   100   0.35   3     POWER MOLD   2SK2201   A  Toshiba
2SK2229   60   0.16   5     TPS   2SK2229   A  Toshiba
2SK2231   60   0.16   5     POWER MOLD   2SK2231   A  Toshiba
2SK2232   60   0.046   25     TO-220IS   2SK2232   A  Toshiba
2SK2233   60   0.03   45     TO-3P(N)   2SK2233   A  Toshiba
2SK2266   60   0.03   45     TO-220FL/SM   2SK2266   A  Toshiba
2SK2267   60   0.011   60     TO-3P(L)   2SK2267   A  Toshiba
2SK2274   700   1.7   5     TO-220IS   2SK2274   A  Toshiba
2SK2311   60   0.046   25     TO-220FL/SM   2SK2311   A  Toshiba
2SK2312   60   0.017   45     TO-220IS   2SK2312   A  Toshiba
2SK2313   60   0.011   60     TO-3P(N)   2SK2313   A  Toshiba
2SK2314   100   0.085   27     TO-220AB   2SK2314   A  Toshiba
2SK2350   200   0.4   8.5     TO-220IS   2SK2350   A  Toshiba
2SK2376   60   0.017   45     TO-220FL/SM   2SK2376   A  Toshiba
2SK2381   200   0.8   5     TO-220IS   2SK2381   A  Toshiba
2SK2382   200   0.18   15     TO-220IS   2SK2382   A  Toshiba
2SK2385   60   0.03   36     TO-220IS   2SK2385   A  Toshiba
2SK2389   700   1.7   5     TO-220AB   2SK2389   A  Toshiba
2SK2391   100   0.085   20     TO-220IS   2SK2391   A  Toshiba
2SK2398   60   0.03   45     TO-3P(N)   2SK2233   A  Toshiba
2SK2399   100   0.23   5     POWER MOLD   2SK2399   A  Toshiba
2SK2400   100   0.23   5     TPS   2SK2400   A  Toshiba
2SK2401   200   0.18   15     TO-220FL/SM   2SK2401   A  Toshiba
2SK2417   250   0.5   7.5     TO-220IS   2SK2417   A  Toshiba
2SK2440   20   0.038   6     SOP-8(单)   TPC8008   A  Sanyo
2SK2441   20   0.032   7     SOP-8(单)   TPC8008   A  Sanyo
2SK2442   30   0.029   7     SOP-8(单)   TPC8006-H  A  Sanyo
2SK2445   60   0.018   50     TO-3P(N)   2SK2445   A  Toshiba
2SK2466   100   0.046   30     TO-220IS   2SK2466   A  Toshiba
2SK2493   16   0.1   5     POWER MOLD   2SK2493   A  Toshiba
2SK2507   50   0.046   25     TO-220IS   2SK2507   A  Toshiba
2SK2508   250   0.25   13     TO-220IS   2SK2508   A  Toshiba
2SK2542   500   0.85   8     TO-220AB   2SK2542   A  Toshiba
2SK2543   500   0.85   8     TO-220IS   2SK2543   A  Toshiba
2SK2544   600   1.25   6     TO-220AB   2SK2544   A  Toshiba
2SK2545   600   1.25   6     TO-220IS   2SK2545   A  Toshiba
评论(3)
发评论
108640983 2012-02-19
0 回复 举报
谢谢你的无私贡献我学习个。 收起回复
dakin 2011-02-19
0 回复 举报
hao 收起回复
全部评论
下载排行榜
全部3条评论
