ID 型号 厂家 用途 构造 沟道 方式 v111(V) 区分 ixing(A) pdpch(W) waixing
1 2SJ11 东芝 DC, LF A, Chop J P D 20 GDS -10m 100m 4-2
2 2SJ12 东芝 DC, LF A, Chop J P D 20 GDS -10m 100m 4-2
3 2SJ13 东芝 DC, LF A, Chop J P D 20 GDS -100m 600m 4-35
4 2SJ15 富士通 DC, LF A J P 18 GDO -10m 200m 4-1
5 2SJ16 富士通 DC, LF A J P 18 GDO -10m 200m 4-1
6 2SJ17 C-MIC J P 20 GDO 0.5m 10m 4-47
7 2SJ18 LF PA J(V) P 170 GDO -5 63 4-45
8 2SJ19 NEC LF D J(V) P 140 GDO -100m 800m 4-41
9 2SJ20 NEC LF PA J(V) P 100 GDO -10 100 4-42
10 2SJ22 C-MIC J P D 80 GDO 0.5m 50m 4-48
11 2SJ39 三菱 LF A J P D 50 GDO -10m .15/CH 4-81
12 2SJ40 三菱 LF A,A-SW J P D 50 GDO -10m 300m 4-151
13 2SJ43 松下 LF A J P D 50 GDS 20m 250m 4-80A
14 2SJ44 NEC LF LN A J P D 40 GDO -10m 400m 4-53A
15 2SJ45 NEC LF A J P D 40 GDO -10m 400m 4-53A
16 2SJ47 日立 LF PA MOS P E -100 DSX -7 100 4-28A
17 2SJ48 日立 LF PA, HS PSW MOS P E -120 DSX -7 100 4-28A
18 2SJ49 日立 LF PA,HS PSW MOS P E -140 DSX -7 100 4-28A
19 2SJ49(H) 日立 HS PSW MOS P E -140 DSX -7 100 4-28A
20 2SJ50 日立 LF/HF PA,HS PSW MOS P E -160 DSX -7 100 4-28A
21 2SJ50(H) 日立 HS PSW MOS P E -160 DSX -7 100 4-28A
22 2SJ51 日立 LF LN A J P D 40 GDO -10m 800m 4-97A
23 2SJ55 日立 LF/HF PA,HS PSW MOS P E -180 DSX -8 125 4-28A
24 2SJ56 日立 LF/HF PA,HS PSW MOS P E -200 DSX -8 125 4-28A
25 2SJ56(H) 日立 HF PA, HS PSW MOS P E -200 DSX -8 125 4-28A
26 2SJ68 日立 LF LN A J P D -40 DSX -10m 300m 4-79A
27 2SJ69 日立 LF LN A J P D -40 DSX -10m 300m 4-79A
28 2SJ70 日立 LF LN A J P D -40 DSX -10m 800m 4-97A
29 2SJ72 东芝 LF LN A J P D 25 GDS -10m 600m 4-74A
30 2SJ73 东芝 LF LN A J P D 25 GDS -10m 0.6/CH 4-98
31 2SJ74 东芝 LF LN A J P D 25 GDS -10m 400m 4-90
32 2SJ75 东芝 LF LN A J P D 25 GDS -10m 0.4/CH 4-99
33 2SJ76 日立 LF D,HS PSW MOS P E -140 DSX -500m 30 4-116A
34 2SJ77 日立 LF D,HS PSW MOS P E -160 DSX -500m 30 4-116A
35 2SJ77(K) 日立 HF PA, HS PSW MOS P E -160 DSX -500m 30 4-116A
36 2SJ78 日立 LF D,HS PSW MOS P E -180 DSX -500m 30 4-116A
37 2SJ79 日立 LF D, HS PSW MOS P E -200 DSX -500m 30 4-116A
38 2SJ79(K) 日立 HF PA, HS PSW MOS P E -200 DSX -500m 30 4-116A
39 2SJ81 日立 LF PA MOS P -120 DSX -7 100 4-117A
40 2SJ82 日立 LF PA MOS P -140 DSX -7 100 4-117A
41 2SJ83 日立 LF PA MOS P -160 DSX -7 100 4-117A
42 2SJ84 松下 LF A J P D 15 GDS -10m 200m 4-105A
43 2SJ85 日立 LF PA MOS P
44 2SJ86 日立 LF PA MOS P
45 2SJ87 日立 LF PA MOS P
46 2SJ90 东芝 LF LN A J P D 30 GDS -10m 0.2/CH 4-75
47 2SJ91 东芝 LF PA MOS P -140 DSX -8 120 4-118
48 2SJ92 东芝 LF PA MOS P -140 DSX -7 100 4-119
49 2SJ96 日立 LF/HF PA, HS PSW MOS P -60 DSX -8 100 4-117A
50 2SJ99 日立 LF/HF PA, HS PSW MOS P E -140 DSS -8 100 4-117B
51 2SJ100 日立 LF/HF PA, HS PSW MOS P E -160 DSS -8 100 4-117B
52 2SJ101 日立 LF/HF PA, HS PSW MOS P E -40 DSS -5 30 4-116B
53 2SJ102 日立 LF/HF PA, HS PSW MOS P E -60 DSS -5 30 4-116B
54 2SJ103 东芝 LF A,A-SW J P D 50 GDS -10m 300m 4-82B
55 2SJ104 东芝 LF A, A-SW J P D 25 GDS -10m 400m 4-82C
56 2SJ105 东芝 LF A,A-SW J P D 50 GDS -10m 200m 4-70A
57 2SJ106 东芝 LF A,A-SW J P D 50 GDS -10m 150m 4-105A
58 2SJ107 东芝 LF A,A-SW J P D 25 GDS -10m 200m 4-70B
59 2SJ108 东芝 LF LN A J P D 25 GDS -10m 200m 4-70B
60 2SJ109 东芝 LF LN A J P D 30 GDS -10m 200m 4-148
61 2SJ110 东芝 LF A,A-SW J P D 25 GDS -10m 400m 4-82C
62 2SJ111 东芝 LF LN A J P D 25 GDS -10m 400m 4-82C
63 2SJ112 日立 HS PSW, RF PA MOS P E -100 DSS -10 100 4-28B
64 2SJ113 日立 HS PSW, RF PA MOS P E -100 DSS -10 100 4-149
65 2SJ114 日立 HS PSW, RF PA MOS P E -200 DSS -8 100 4-149
66 2SJ115 东芝 LF PA MSO P E -160 DSS -8 100 4-119
67 2SJ116 日立 HS PSW, RF PA MOS P E -400 DSS -8 125 4-28B
68 2SJ117 日立 HS PSW, RF PA MOS P E -400 DSS -2 40 4-116B
69 2SJ118 日立 HS PSW, RF PA MOS P E -140 DSS -8 100 4-149
70 2SJ119 日立 HS PSW, RF PA MOS P E -160 DSS -8 100 4-149
71 2SJ120(L) 日立 HS PSW, RF PA MOS P E -40 DSS -2 10 4-150
72 2SJ122 日立 HS PSW, RF PA MOS P E -60 DSS -10 50 4-116B
73 2SJ123 东芝 LF PA, HS SW MOS P E -70 DSS -10 30 4-138
74 2SJ125 三菱 LF PA,A-SW J P D 50 DGO -10m 150m 4-128
75 2SJ126 东芝 HS SW MOS P E -60 DSX -10 40 4-182
76 2SJ127 日立 HS PSW MOS P E -120 DSS -10 50 4-116B
77 2SJ128,128Z NEC SW MOS P E -100 DSS ±2 20 4-276/Z:281
78 2SJ129 松下 LF A J P D 50 GDS -10m 300m 4-213B
79 2SJ130(L)(S) 日立 HS SW MOS P E -300 DSS -1 20 4-150
80 2SJ131 SW MOS P E -170 DSS -10 100 4-207
81 2SJ132,132Z NEC SW MOS P E -30 DSS ±2 20 4-276/Z:281
82 2SJ133,133Z NEC SW MOS P E -60 DSS ±2 20 4-276/Z:281
83 2SJ134 NEC SW MOS P E -100 DSS ±6 20 4-164
84 2SJ135 NEC SW MOS P E -100 DSS ±5 30 4-274
85 2SJ136 NEC SW MOS P E -60 DSS ±12 40 4-164
86 2SJ137 NEC SW MOS P E -60 DSS ±10 30 4-274
87 2SJ138 NEC SW MOS P E -100 DSS ±12 60 4-164
88 2SJ139 NEC SW MOS P E -100 DSS ±10 35 4-274
89 2SJ140 NEC SW MOS P E -60 DSS ±19 60 4-164
90 2SJ141 NEC SW MOS P E -60 DSS ±13 35 4-274
91 2SJ142 NEC SW MOS P E -100 DSS ±13 35 4-274
92 2SJ143 NEC SW MOS P E -60 DSS ±16 35 4-274
93 2SJ144 东芝 LF A-SW J P D 50 GDS -10m 100m 4-246B
94 2SJ145 三菱 LF A-SW J P D 50 GDO -10m 150m
95 2SJ146 松下 SW MOS P E -50 DSS -100m 150m 4-193B
96 2SJ147 东芝 DDC, Motor D MOS P E -60 DSS -12 40 4-182
97 2SJ148 东芝 HS SW, A-SW MOS P E -60 DSX -200m 400m 4-82D
98 2SJ151 NEC SW MOS P E -100 DSS ±3 35 4-164
99 2SJ152 NEC SW MOS P E -100 DSS ±3 30 4-274
100 2SJ153 NEC SW MOS P E -60 DSS ±6 40 4-164
101 2SJ154 NEC SW MOS P E -60 DSS ±5 30 4-274
102 2SJ155 松下 SW MOS P E -50 DSS -3 30 4-190
103 2SJ156 松下 SW MOS P E -50 DSS -5 30 4-190
104 2SJ157 松下 SW MOS P E -100 DSS -3 30 4-190
105 2SJ158 松下 SW MOS P E -100 DSS -5 30 4-190
106 2SJ159 松下 SW MOS P E -160 DSS -3 30 4-190
107 2SJ160 日立 LF PA MOS P E -120 DSX -7 100 4-149
108 2SJ161 日立 LF PA MOS P E -140 DSX -7 100 4-149
109 2SJ162 日立 LF PA MOS P E -160 DSX -7 100 4-149
110 2SJ163 松下 SW J P D 65 GDS -10m 150m 4-193D
111 2SJ164 松下 SW J P D 65 GDS -10m 300m 4-213C
112 2SJ165 NEC HS SW MOS P E -50 DSS -0.1 250m 4-104C
113 2SJ166 NEC HS SW MOS P E -50 DSS -0.1 200m 4-275A
114 2SJ167 东芝 HS SW, A-SW MOS P E -60 DSS -200m 300m 4-70
115 2SJ168 东芝 HS SW, A-SW MOS P E -60 DSS -200m 200m 4-105D
116 2SJ169 日立 SW-Reg, DDC MOS P E -60 DSS -12 50 4-116B
117 2SJ170 日立 SW-Reg, DDC MOS P E -80 DSS -12 50 4-116B
118 2SJ171 日立 SW-Reg, DDC MOS P E -50 DSS -9.7 40 4-116B
119 2SJ172 日立 Motor/Relay-D MOS P E -60 DSS -10 40 4-116B
120 2SJ173 日立 Motor/Relay-D MOS P E -60 DSS -15 50 4-116B
121 2SJ174 日立 Motor/Relay-D MOS P E -60 DSS -20 75 4-116B
122 2SJ175 日立 Motor/Relay-D MOS P E -60 DSS -10 25 4-292
123 2SJ176 日立 Motor/Relay-D MOS P E -60 DSS -15 30 4-292
124 2SJ177 日立 Motor/Relay-D MOS P E -60 DSS -20 35 4-292
125 2SJ178 NEC HS SW MOS P E -30 DSS ±1 0.75 4-53C
126 2SJ179 NEC HS SW MOS P E -30 DSS ±1.5 2 4-216A
127 2SJ180 NEC HS SW MOS P E -30 DSS ±1 1 4-217
128 2SJ181(L)(S) 日立 SW-Reg, DDC MOS P E -600 DSS -0.5 20 4-150
129 2SJ182(L)(S) 日立 Motor/Relay-D MOS P E -60 DSS -3 20 4-150
130 2SJ183 东芝 Relay-D, DDC MOS P E -60 DSS -5 20 4-257
131 2SJ184 NEC HS SW MOS P E -50 DSS -100m 250m 4-104C
132 2SJ185 NEC HS SW MOS P E -50 DSS -100m 200m 4-275A
133 2SJ186 日立 SW-Reg, DDC MOS P E -200 DSS -0.5 1 4-295
134 2SJ187 三洋 SW MOS P E -30 DSS -1 3.5 4-252
135 2SJ188 三洋 SW MOS P E -30 DSS -2 20 4-346
136 2SJ189 三洋 SW MOS P E -30 DSS -4 30 4-346
137 2SJ190 三洋 SW MOS P E -60 DSS -1 3.5 4-252
138 2SJ191 三洋 SW MOS P E -60 DSS -2 20 4-346
139 2SJ192 三洋 SW MOS P E -60 DSS -4 30 4-346
140 2SJ193 三洋 SW MOS P E -100 DSS -1 3.5 4-252
141 2SJ194 三洋 SW MOS P E -100 DSS -2 20 4-346
142 2SJ195 三洋 SW MOS P E -100 DSS -4 30 4-346
143 2SJ196 NEC SW MOS P E -60 DSS ±1 0.75 4-53C
144 2SJ197 NEC SW MOS P E -60 DSS ±1 2 4-216A
145 2SJ198 NEC SW MOS P E -100 DSS ±0.5 0.75 4-53D
146 2SJ199 NEC SW MOS P E -100 DSS ±1 2 4-216A
147 2SJ200 东芝 LF PA MOS P E -180 DSS -10 120 4-184
148 2SJ201 东芝 LF PA MOS P E -200 DSS -12 150 4-337
149 2SJ202 NEC SW MOS P E -16 DSS -100m 150m 4-246C
150 2SJ203 NEC SW MOS P E -16 DSS -200m 200m 4-275A
151 2SJ204 NEC SW MOS P E -30 DSS -200m 200m 4-275A
152 2SJ205 NEC SW MOS P E -16 DSS ±0.5 2 4-216A
153 2SJ206 NEC SW MOS P E -30 DSS ±0.5 2 4-216A
154 2SJ207 NEC SW MOS P E -16 DSS ±1 2 4-216A
155 2SJ208 NEC SW MOS P E -16 DSS ±2 2 4-216A
156 2SJ209 NEC SW MOS P E -100 DSS -100m 200m 4-275A
157 2SJ210 NEC SW MOS P E -60 DSS -200m 200m 4-275A
158 2SJ211 NEC SW MOS P E -100 DSS -200m 200m 4-275A
159 2SJ212 NEC SW MOS P E -60 DSS ±0.5 2 4-216A
160 2SJ213 NEC SW MOS P E -100 DSS ±0.5 2 4-216A
161 2SJ214(L)(S) 日立 Motor/Relay-D MOS P E -60 DSS -105 40 4-294
162 2SJ215 日立 Motor/Relay-D MOS P E -60 DSS -35 125 4-149
163 2SJ216 日立 Motor/Relay-D MOS P E -60 DSS -35 60 4-293
164 2SJ217 日立 Motor/Relay-D MOS P E -60 DSS -45 150 4-149
165 2SJ218 日立 Motor/Relay-D MOS P E -60 DSS -45 75 4-293
166 2SJ219(L)(S) 日立 Motor/Relay-D MOS P E -60 DSS -15 50 4-294
167 2SJ220(L)(S) 日立 Motor/Relay-D MOS P E -60 DSS -20 75 4-294
168 2SJ221 日立 Motor/Relay-D MOS P E -100 DSS -20 75 4-116B
169 2SJ222 日立 Motor/Relay-D MOS P E -100 DSS -15 35 4-292
170 2SJ223(L)(S) 日立 HS PSW MOS P E -60 DSS -2 10 4-150
171 2SJ224 东芝 SW, DDC, Motor-D MOS P E -60 DSS -12 80 4-341
172 2SJ225 三洋 HS SW MOS P E -30 DSS -1 1 4-348
173 2SJ226 三洋 HS SW MOS P E -30 DSS -2 1.5 4-347
174 2SJ227 三洋 HS SW MOS P E -30 DSS -3 1.5 4-347
175 2SJ228 三洋 HS SW MOS P E -60 DSS -0.8 1 4-348
176 2SJ229 三洋 HS SW MOS P E -60 DSS -1.6 1.5 4-347
177 2SJ230 三洋 HS SW MOS P E -60 DSS -2.5 1.5 4-347
178 2SJ231 三洋 HS SW MOS P E -100 DSS -0.5 1 4-348
179 2SJ232 三洋 HS SW MOS P E -100 DSS -2.5 1.5 4-347
180 2SJ233 三洋 HS SW MOS P E -100 DSS -2.5 1.5 4-347
181 2SJ234(L)(S) 日立 HS PSW, DDC MOS P E -30 DSS -2.5 10 4-150
182 2SJ235(L)(S) 日立 HS PSW MOS P E -60 DSS -3 20 4-150
183 2SJ236 日立 HS PSW MOS P E -60 DSS -10 25 4-376
184 2SJ237 日立 HS PSW MOS P E -60 DSS -15 30 4-376
185 2SJ238 东芝 SW, DDC, Motor-D MOS P E -60 DSS -1 0.5 4-256
186 2SJ239 东芝 SW, DDC, Motor-D MOS P E -60 DSS -5 20 4-257
187 2SJ240 东芝 SW, DDC, Motor-D MOS P E -60 DSS -20 45 4-335
188 2SJ241 东芝 SW, DDC, Motor-D MOS P E -60 DSS -20 100 4-341
189 2SJ243 NEC SW MOS P E -30 DSS ±100m 200m 4-356
190 2SJ244 日立 HS PSW, DDC MOS P E -12 DSS ±2 1 4-295
191 2SJ245(L)(S) 日立 HS PSW, DDC MOS P E -60 DSS -5 20 4-150
192 2SJ246(L)(S) 日立 HS PSW, DDC MOS P E -30 DSS -7 20 4-150
193 2SJ247 日立 HS PSW MOS P E -100 DSS -8 40 4-116B
194 2SJ248 日立 HS PSW, DDC MOS P E -100 DSS -8 25 4-292
195 2SJ250 日立 HS PSW MOS P E -60 DSS -10 12 4-363A
196 2SJ254 三洋 HS SW MOS P E -30 DSS -8 25 4-284
197 2SJ255 三洋 HS SW MOS P E -30 DSS -10 25 4-284
198 2SJ256 三洋 HS SW MOS P E -30 DSS -18 30 4-284
199 2SJ257 三洋 HS SW MOS P E -30 DSS -10 50 4-370
200 2SJ258 三洋 HS SW MOS P E -30 DSS -12 60 4-370
201 2SJ259 三洋 HS SW MOS P E -30 DSS -20 70 4-370
202 2SJ263 三洋 HS SW MOS P E -60 DSS -6 25 4-284
203 2SJ264 三洋 HS SW MOS P E -60 DSS -8 25 4-284
204 2SJ265 三洋 HS SW MOS P E -60 DSS -15 30 4-284
205 2SJ266 三洋 HS SW MOS P E -60 DSS -8 50 4-370
206 2SJ267 三洋 HS SW MOS P E -60 DSS -10 60 4-370
207 2SJ268 三洋 HS SW MOS P E -60 DSS -18 70 4-370
208 2SJ272 三洋 HS SW MOS P E -100 DSS -4 25 4-284
209 2SJ273 三洋 HS SW MOS P E -100 DSS -6 25 4-284
210 2SJ274 三洋 HS SW MOS P E -100 DSS -12 30 4-284
全部24条评论
