KS8993 Product Brief
消耗积分:2 | 格式:rar | 大小:222 | 2009-03-19
分享资料个
Micrel’s KS8993 is the world’s first integrated threeport
10/100 Fast Ethernet switch with enhanced QoS. This
device integrates three 10BASET/100BASETX
transceivers, three MAC (Media Access Control) units
with high-speed layer 2 switch and 64k Byte embedded
frame buffer.
The KS8993 runs in two modes. The first mode is a
three-port integrated switch and the second is as a threeport
switch with the third port decoupled from the
physical port. In this mode access to the third MAC is
provided using a reverse or forward MII (Media
Independent Interface) such that an external MAC can
be directly connected to the KS8993. This interface also
supports the 7-wire (serial network inteface) as used by some routing devices.
评论(0)
发评论
下载排行榜
