MAXQ618,pdf_具有红外模块的16位微控制器
消耗积分:10 | 格式:exe | 大小:1.9 MB | 2011-03-13
王军
分享资料个
The MAXQ618 is a low-power, 16-bit MAXQ® microcontroller designed for low-power applications including universal remote controls, consumer electronics, and white goods. The device combines a powerful 16-bit RISC microcontroller and integrated peripherals including two universal synchronous/asynchronous receiver-transmitters (USARTs) and an SPI™ master/slave communications port, along with an IR module with carrier frequency generation and flexible port I/O capable of multiplexed keypad control.
The device includes 80KB of flash memory and 2KB of data SRAM. The MAXQ61C is a ROM version of this device.
For the ultimate in low-power battery-operated performance, the device includes an ultra-low-power stop mode (0.2µA typ). In this mode, the minimum amount of circuitry is powered. Wake-up sources include external interrupts, the power-fail interrupt, and a timer interrupt. The microcontroller runs from a wide 1.70V to 3.6V operating voltage.
关键特性
High-Performance, Low-Power, 16-Bit RISC Core
DC to 12MHz Operation Across Entire Operating Range
1.70V to 3.6V Operating Voltage
33 Total Instructions for Simplified Programming
Three Independent Data Pointers Accelerate Data Movement with Automatic Increment/Decrement
Dedicated Pointer for Direct Read from Code Space
16-Bit Instruction Word, 16-Bit Data Bus
16 x 16-Bit General-Purpose Working Registers
Memory Features
80KB Flash Memory
2KB Data SRAM
Additional Peripherals
Power-Fail Warning
Power-On Reset (POR)/Brownout Reset
Automatic IR Carrier Frequency Generation and Modulation
Two 16-Bit Programmable Timers/Counters with Prescaler and Capture/Compare
One SPI Port and Two USART Ports
Programmable Watchdog Timer
8kHz Nanopower Ring Oscillator Wake-Up Timer
Up to 32 General-Purpose I/Os
Low Power Consumption
0.2µA (typ), 2.0µA (max) in Stop Mode, TA = +25°C, Power-Fail Monitor Disabled
2.0mA (typ) at 12MHz in Active Mode
应用/使用
电池供电便携式设备
消费类电子
家用产品
远端控制
白色家电
评论(0)
发评论
下载排行榜
