基于MAXQ微控制器的嵌入式工作台设计
消耗积分:0 | 格式:pdf | 大小:141 KB | 2011-03-28
刘明
分享资料个
  Abstract: This article is a step-by-step guide to successfully add Gimpel Software's PC-lint version 9 as a tool in an IAR™ C compiler for MAXQ version 2.20I.
  Introduction
  To provide ongoing support for MAXQ microcontrollers and development of application firmware, Maxim is simplifying the integration of PC-lint from Gimpel Software into an IAR Embedded Workbench® C compiler.
  Many developers use the popular static code analyzer, PC-lint, during code development. This article guides you to successfully add PC-lint version 9 as a tool in an IAR C compiler for MAXQ version 2.20I.
  Integration Procedure
  Install a copy of PC-lint version 9 to its default directory of C:\lint and install a copy of the IAR Embedded Workbench software with the C compiler for MAXQ version 2.20I on the PC.
评论(0)
发评论
下载排行榜
