The LIS352AX has a full scale of ±2g and it is
capable of measuring accelerations over a
maximum bandwidth of 2.0 kHz. The device
bandwidth may be reduced by using external
capacitances.
The self-test capability allows the user to check
the functioning of the system.
An embedded multiplexer allows to redirect the
analog outputs onto a single pin for operation with
a single channel A/D converter.
ST is already in the field with several hundreds
million sensors with excellent acceptance from
the market in terms of quality, reliability and
performance.
