Persons supervising and performing the electrical installation or
maintenance of a Drive and/or an external Option Unit must be suitably
qualified and competent in these duties. They should be given the
opportunity to study and if necessary to discuss this User Guide before
work is started.
The voltages present in the Drive and external Option Units are capable of
inflicting a severe electric shock and may be lethal. The Stop function of
the Drive does not remove dangerous voltages from the terminals of the
Drive and external Option Unit. Mains supplies should be removed before
any servicing work is performed.
