ds1682 pdf datasheet (Total-El
消耗积分:5 | 格式:rar | 大小:444 | 2009-04-02
vinww特烦恼
分享资料个
The DS1682 is an integrated elapsed-time recorder containing a factory-calibrated, temperature-compensated RC time base that eliminates the need for an external crystal. Using EEPROM technology to maintain data in the absence of power, the DS1682 requires no backup power source. The DS1682 detects and records the number of events on the EVENT pin and the total cumulative event time since the DS1682 was last reset to 0. The active-low ALARM pin alerts the user when the total time accumulated equals the user-programmed alarm value. The polarity of the open-drain active-low ALARM pin can be programmed to either drive low or to become high impedance upon an alarm condition. The DS1682 is ideal for applications that monitor the total amount of time that a device has been in operation and/or the number of uses since inception of service, repair, or the last calibration.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
