农业和粮食生产是社会的一个主要方面,日常生活直接受到它的影响。我们正在寻求创建一个小型模型监测和抽水系统,以帮助维持家庭种植的植物的水位。未来的补充可以是大气水和温度监测。该项目旨在通过仔细平衡植物内的水位以确保不会因浇水过多或浇水不足而造成作物损失,至少是在小范围内解决作物损失问题。
第 1 步:创建电路
按照链接的 Fritzing 图或面包板图像将电路放在一起。
第 2 步:云交互
在 IoT Cloud 上创建东西以设置用于云连接的仪表板
首先在 Arduino IoT Cloud 上创建“事物”。然后创建你的三个变量;给出了信息。查看仪表板图像以查看变量是“只读”还是“读/写”。最后创建仪表板并将变量链接到适当的小部件。
第 3 步:代码 [.ino]
将以下代码复制到 Arduino IDE 中...
Sketch generated by the Arduino IoT Cloud Thing "AutoGarden"
https://create.arduino.cc/cloud/things/36881e31-0b15-4ae9-ad3d-c0bee1f0ea06
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
int moisture;
bool RunPump;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#define PumpRunner 0 // set the pin for the pump
int val = 0; // returned value from soil moisture sensor
int soilPin = A0; // pin for reading from the soil moisture sensor
int soilPower = 7; // pin for powering the the soil moisture sensor.
int setMLevel;
void setup() {
// Initialize serial and wait for port to open:
Serial.begin(9600);
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
pinMode(PumpRunner, OUTPUT);
pinMode(soilPower, OUTPUT);
digitalWrite(soilPower, LOW);
void loop() {
ArduinoCloud.update();
// Your code here
moisture = readSoil();
moisture = map(moisture, 0, 700, 0, 100);
Serial.println(moisture);
digitalWrite(PumpRunner, LOW);
delay(1000);
if(moisture <= setMLevel && moisture >= 10){
RunPump = true;
if(RunPump){
digitalWrite(PumpRunner, HIGH);
delay(1000); // pump takes a second or two to start up
delay(1000); // one second delay so water can settle
RunPump = false;
delay(1000);// remaining delay, go to value minus 3010
int readSoil(){
digitalWrite(soilPower, HIGH);
delay(10);
val = analogRead(soilPin);
return val;
第 4 步:属性代码
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char THING_ID[] = "36881e31-0b15-4ae9-ad3d-c0bee1f0ea06";
const char SSID[] = SECRET_SSID; // Network SSID (name)
const char PASS[] = SECRET_PASS; // Network password (use for WPA, or use as key for WEP)
void onSetMLevelChange();
void onRunPumpChange();
int moisture;
int setMLevel;
bool RunPump;
void initProperties(){
ArduinoCloud.setThingId(THING_ID);
ArduinoCloud.addProperty(moisture, READ, ON_CHANGE, NULL);
ArduinoCloud.addProperty(setMLevel, READWRITE, ON_CHANGE, onSetMLevelChange);
ArduinoCloud.addProperty(RunPump, READWRITE, ON_CHANGE, onRunPumpChange);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
第 5 步:设置 Internet 连接
在 Arduino 编辑器的“秘密”选项卡中,设置您的无线网络 ID 和密码。测试并确保您的设备正确连接到云。
运行这个项目有几个风险。
