RDA5868 is a highly integrated single-chip IC with radio transceiver and baseband processor, which is compliant with Bluetooth 2.1 + EDR specification and provides an optimal solution for data and voice application.The RDA5868 provides either UART or USB which are specified as HCI interfaces by Bluetooth SIG standard, and also supports PCM audio interface.The RDA5868 has been designed on highest level of integration to extremely reduce the number of external component. It uses CMOSprocess with a compact 6*6mm package size.
