中频低损耗功率铁氧体材料TP4/TP4A/TP4S
消耗积分:0 | 格式:ppt | 大小:2.63 MB | 2011-06-15
wipak
分享资料个
 中频低损耗功率铁氧体材料
   TP4、TP4A & TP4S
Middle frequency, low core loss power ferrite material
TP4、TP4A & TP4S
特点:
Features:
TP4系列材料是一类典型的低损耗材料,主要应用于中频段(~300kHz)。
   TP4 series material ,a series of typical low core loss material, mostly are used at middle frequency (~300 kHz).
具有很低的磁芯损耗和很高的饱和磁感应强度(25℃时大于500mT,100℃时
   大于390mT)
   The core loss is very low and the saturation flux density is very high.  (more than 500mT at 25℃, more than 390mT at 100℃)
TP4和TP4A磁芯损耗的最低温度点约在90℃,TP4S可用于更高的温度,其磁芯损耗的温度最低点在100~110℃.
   The temperature of the lowest core loss of TP4 and TP4A is on about 90℃,TP4S can be used within higher temperature band and the temperature of the lowest core loss of  TP4S is on 100~110℃.
应用:
Application:
 功率变压器:Power transformer
 功率电感:Power inductance
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
