蓝牙低功耗技术提供了一种连接智能设备的合适方式。物联网(IoT)或物联网(Internet of Things)这个词带来了新技术,在连接时代改变和创造世界。物联网表示一切都已连接,而蓝牙使工作变得更加容易。一台中央设备可以启动并保持与多个低功耗蓝牙外围设备的连接。
BleuIO 是一种蓝牙低功耗解决方案,可以以最快、最简单的方式创建新的 BLE 5.0 应用程序。使用此 BleuIO 的多连接功能,我们可以轻松连接到多个 BLE 设备并在它们之间传输数据。
本文将解释如何使用 BleuIO 的多连接功能,连接多个 BLE 设备并在它们之间传输数据。我们将为这个项目使用三个 BleuIO 加密狗:一个中央和两个外围。中央加密狗将连接到外围设备并同时发送数据。
我们将创建一个简单的 python 脚本来帮助我们完成任务。
步骤1:
让我们创建一个名为py_serial_transfer.py的 python 文件并复制以下代码。
源代码也可以在 GitHub 上获得
https://github.com/smart-sensor-devices-ab/ble_multi_connection_example.git
#!/usr/bin/python
# -*- coding: utf-8 -*-
import serial
import time
import string
import random
target_dongle_mac_address = '[0]40:48:FD:E5:2D:AF' # Change this to the 1st peripheral's mac address.
target_dongle_mac_address2 = '[0]40:48:FD:E5:2D:B5' # Change this to the 2nd peripheral's mac address.
your_com_port = 'COM7' # Change this to the com port your dongle is connected to.
connecting_to_dongle = True
trying_to_connect = False
trying_to_connect2 = False
def id_generator(size=10, chars=string.ascii_uppercase + string.digits):
return ''.join(random.choice(chars) for _ in range(size))
print 'Connecting to dongle...'
# Trying to connect to dongle until connected. Make sure the port and baudrate is the same as your dongle.
# You can check in the device manager to see what port then right-click and choose properties then the Port Settings
# tab to see the other settings
while connecting_to_dongle:
try:
console = serial.Serial(
port=your_com_port,
baudrate=57600,
parity='N',
stopbits=1,
bytesize=8,
timeout=0,
if console.is_open.__bool__():
connecting_to_dongle = False
except:
print 'Dongle not connected. Please reconnect Dongle.'
time.sleep(5)
print 'Connected to Dongle.'
connected = '0'
connected2 = '0'
while 1 and console.is_open.__bool__():
console.write(str.encode('AT+DUAL'))
console.write('\r'.encode())
time.sleep(0.1)
print 'Putting dongle in Dual role and trying to connect to other dongle.'
while connected == '0':
time.sleep(0.5)
if not trying_to_connect:
console.write(str.encode('AT+GAPCONNECT='))
console.write(str.encode(target_dongle_mac_address))
trying_to_connect = True
dongle_output2 = console.read(console.in_waiting)
time.sleep(2)
print 'Trying to connect to Peripheral 1...'
if not dongle_output2.isspace():
if dongle_output2.decode().__contains__('\r\nCONNECTED.'):
connected = '1'
print 'Connected to 1st device!'
time.sleep(5)
if dongle_output2.decode().__contains__('\r\nDISCONNECTED.'
connected = '0'
print 'Disconnected!'
dongle_output2 = ' '
while connected2 == '0':
time.sleep(0.5)
if not trying_to_connect2:
console.write(str.encode(target_dongle_mac_address2))
trying_to_connect2 = True
time.sleep(2)
print 'Trying to connect to Peripheral 2...'
connected2 = '1'
print 'Connected to 2nd device!'
time.sleep(5)
connected2 = '0'
while connected == '1' and connected2 == '1':
dongle_output3 = console.read(console.in_waiting)
delay = 10
close_time = time.time() + delay
i = 0
while True:
myConIndex = ('0000' if i % 2 == 0 else '0001')
console.write(str.encode('AT+TARGETCONN='))
console.write(str.encode(myConIndex))
console.write(str.encode('AT+SPSSEND='))
console.write(str.encode(id_generator() + '-' + myConIndex))
time.sleep(0.2)
i += 1
if time.time() > close_time:
break
console.write(str.encode('AT+SPSSEND=[DONE]\r'))
time.sleep(0.2)
print 'Sending complete!\r\n'
print 'Exiting script...'
exit()
该脚本将用于中央 BleuIO 加密狗。我们需要找到每个加密狗的端口号和外设mac地址。
第2步:
在您的 PC 上连接三个 BleuIO 加密狗。您可以在三台不同的 PC 或 Raspberry Pi 上执行此过程。
为此项目,我已将中央和外围设备连接到一台 PC。
连接加密狗后,打开设备管理器(windows)找到每个加密狗的端口。
在我的 PC 上,我在端口 7、8 和 18 上连接了 BleuIO 加密狗。
让我们以 COM7 为中心,COM8 和 COM18 为外围。
现在打开脚本并在第 12 行设置端口号。
我们还需要知道外围加密狗的 MAC 地址。
为此,我们可以简单地使用AT+ADVSTART命令宣传加密狗。
对其他外围加密狗执行相同的过程。
现在这两个外围加密狗都在做广告。我们可以从中心进行间隙扫描以找到他们的 MAC 地址。
现在寻找名为BleuIO 的加密狗。
使用外设 mac 地址更新脚本(第 6、9 行)
第 3 步:
现在让我们运行脚本。
