MAX1464 Signal-Conditioner, Se
消耗积分:3 | 格式:rar | 大小:474 | 2009-04-17
分享资料个
The MAX1464 is a fully digital, high-performance signal conditioner with multichannel inputs, analog and
digital outputs, and support for 4-20mA output applications. The MAX1464 can be programmed to correct the
nonlinearities and temperature dependent characteristics of sensors.
This document describes the procedures to compensate and calibrate a sensor signal that is applied to one of
the MAX1464's ADC channels. The algorithm provides offset and span correction over the specified temperature
range. It is assumed that the MAX1464 VDD supply voltage does not change during the compensation
process and operation of the device.
The data presented in this document is real data acquired from a piezoresistive pressure sensor used to
demonstrate the compensation algorithm.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
