AGM CPLD DATASHEET AG_CPLD_Rev
消耗积分:0 | 格式:pdf | 大小:0.30 MB | 2023-11-02
深圳市致知行科技有限公司
  • 364内容
  • 56w+阅读
  • 96粉丝
General Description
AGM CPLD family provides low-cost instant-on, non-volatile CPLDs, with densities from 256, 272 to 576 logic LUTs and non-volatile flash storage of 256Kbits。 The devices offer up to 144 I/O pins featuring with a user flash memory (UFM), and in-system programming。 The devices are designed to reduce cost and power while providing programmable solutions for a  wide range of applications。
 Features
1、Low-Cost and low-power CPLD
2、Instant-on, non-volatile Compatible FPGA architecture。
3、Up to 4 global clock lines in the global clock network that drive throughout the entire device。
4、Provides programmable fast propagation delay and clock-to-output times。
5、Provides PLL per device provide clock multiplication and phaseshifting (AG256 has no PLL)。
6、UFM supports non-volatile storage up to 256 Kbits。
7、Supports 3.3-V, 2.5-V, 1.8-V, and 1.5-V logic level
8、Programmable slew rate, drive strength, bus-hold, programmable pull-up resistors, open-drain output, Schmitt triggers
 and programmable input delay。
9、Built-in Joint Test Action Group (JTAG) boundary-scan test (BST) circuitry complaint with IEEE Std. 1149.1-1990
10、ISP circuitry compliant with IEEE Std。 1532
11、3.3-V, 2.5-V, 1.8-V, 1.5-V LVCMOS and LVTTL standards
12、Emulated LVDS output (LVDS_E_3R)
13、Emulated RSDS output (RSDS_E_3R)
14、Operating junction temperature from -40 to 100 ℃
评论(0)
发评论
下载排行榜
