High-Performance 16-Point Comp
消耗积分:3 | 格式:rar | 大小:333 | 2009-05-14
分享资料个
High-Performance 16-Point Complex FFT
•This document is (c) Xilinx, Inc. 1999. No part of this file may be modified, transmitted to any third party (other than as
intended by Xilinx) or used without a Xilinx programmable or hardwire device without Xilinx's prior written permission.
1 Functional Description
The xFFT16 fast Fourier transform (FFT) Core computes a 16-point complex FFT. The input data is a vector of 16 complex values represented as 16-bit 2’s complement numbers – 16-bits for each of the real and imaginary component of a datum.
2 Theory of Operation
The discrete Fourier transform (DFT) X (k), k = 0,K , N -1of a sequence x(n), n = 0,K , N -1is
defined as:
评论(0)
发评论
下载排行榜
