Multiple-voltage electronics systems often requirecomplex supply voltage tracking or sequencing, whichif not met, can result in system faults or even permanentfailures in the fi eld. The design diffi culties in meetingthese requirements are often compounded in distributedpowerarchitectures where point-of-load (POL) DC/DCconverters or linear regulators are scattered across PCboard space, sometimes on different board planes. Theproblem is that power supply circuitry is often the lastcircuitry to be designed into the board, and it must beshoehorned into whatever little board real estate is left.Often, a simple, drop-in, fl exible solution is needed tomeet these requirements.
