MAX6791–MAX6796高压、微功耗、单双路线性稳压器
消耗积分:1 | 格式:pdf | 大小:331 KB | 2012-02-02
分享资料个
The MAX6791–MAX6796 ultra-low-quiescent-current,single-/dual-output linear regulators are ideal for automotiveapplications. The devices offer a wide 5V to 72Voperating input range, allowing them to withstand automotiveload-dump conditions while consuming only68μA. The MAX6791–MAX6794 are dual-output regulatorscapable of supplying up to 150mA per output. TheMAX6795/MAX6796 offer a single output capable ofdelivering up to 300mA. These devices offer standardoutput-voltage options (5V, 3.3V, 2.5V, or 1.8V) and canbe adjusted to any voltage from 1.8V to 11V. TheMAX6791–MAX6794 also offer a fixed 5V output.
评论(0)
发评论
下载排行榜
