电源调整与虚拟地
消耗积分:0 | 格式:pdf | 大小:33 KB | 2012-03-08
分享资料个
Abstract: Rail splitting is creating an artificial virtual ground as a reference voltage. It is used to set the signalto match the op amp's "sweet spot." An op amp has the most linear- and distortion-free qualities at that sweetspot. Typically, the sweet spot occurs near the center between the single power rail and ground. In the case ofa number of signals, the virtual ground can control channel DC errors when multiplexing or switching thesignals.
评论(0)
发评论
下载排行榜
