The DS1086 EconOscillator™ is a programmable clockgenerator that produces a spread-spectrum (dithered)square-wave output of frequencies from 260kHz to133MHz. The selectable dithered output reduces radiated-emission peaks by dithering the frequency 2% or4% below the programmed frequency. The DS1086 hasa power-down mode and an output-enable control forpower-sensitive applications. All the device settings arestored in nonvolatile (NV) EEPROM memory allowing ito operate in stand-alone applications.
