PCI-EXPRESS CLOCK SOURCE-ICS55
消耗积分:3 | 格式:rar | 大小:333 | 2008-04-01
分享资料个
The ICS557-01 is a clock chip designed for use in
PCI-Express Cards as a clock source. It provides a pair
of differential outputs at 100 MHz in a small 8-pin SOIC
package.
Using ICS’ patented Phase-Locked Loop (PLL)
techniques, the device takes a 25 MHz crystal input
and produces HCSL (Host Clock Signal Level)
differential outputs at 100 MHz clock frequency. LVDS
signal levels can also be supported via an alternative
termination scheme.
评论(0)
发评论
下载排行榜
