M29F400和 M29W400闪速存储器相关技术信息和软件
消耗积分:5 | 格式:rar | 大小:333 | 2009-05-19
362163
分享资料个
This application note provides library source code in C for the
M29F400 and the M29W400 Flash memories. The M29W400,
with a rated power supply of 3V, is a low voltage version of the
M29F400 whose power supply is rated at 5V. The M29W400
has slightly slower access times than the M29F400, but the two
devices are otherwise very similar. This application note supports
both devices and all technical information about the
M29F400 also applies to the M29W400, except where otherwise
specified. There are two different M29F400 parts, the
M29F400B and M29F400T, which will be referred to generically
as the M29F400. Similarly the term M29W400 in this application
note can refer to either the M29W400T or the M29W400B.
评论(0)
发评论
下载排行榜
