Micron公司的MT28F016S5VG与AMD公司的AM
消耗积分:3 | 格式:rar | 大小:333 | 2009-05-19
分享资料个
Because of the nonstandard operation of Flash
memory, hardware and software modifications are sometimes
necessary if multiple memory sources are needed.
Micron's boot block and even-sectored flash memories
are compatible with similar Intel® devices (see Technical
Notes TN-28-05, TN-28-11, and TN-28-14). However,
some accommodations in PCB and software design are
necessary in order to use Micron® and AMD devices in
the same socket. This article explores the differences
between Micron's 16Mb even-sectored byte-wide flash
评论(0)
发评论
下载排行榜
