The 100MHz SDRAM was designed to improve memory bandwidth. It synchronizes the internal operation of the DRAM to a system clock to achieve higher memory bandwidth per pin by pipelining internal operations. It includes multiple independent memory banks to allow the user to hide access and precharge latency, provided that the system can ping-pong between the banks when a new row is opened or closed. This device improves noise immunity to input receivers by essentially ignoring the input pins completely, except during a narrow setup and hold window around the rising edge of the system clock. The device includes a mode register to allow the user to optimize the pipeline length of the device in order to minimize the read to output delay based on the users operating clock frequency. A self refresh mode which was normally offered on more expensive low power EDO devices, is provided as standard equipment.
