如何将CY7C276 高速PROM连接至AT&T, AD,M
消耗积分:3 | 格式:rar | 大小:401 | 2009-05-23
分享资料个
Digital signal processors (DSPs) have typically required two external storage devices—a relatively slow PROM (Programmable Read Only Memory) for non-volatile code storage, and an SRAM (Static Random Access Memory), faster than the PROM, from which to run the code. The reason for this is that PROM access times are typically too slow to meet the requirements of the DSP cycle times.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
