首先将模糊神经网络应用于单传感器潜艇目标识别,在此基础上将多传感器数据融合技术应用于目标识别。仿真结果证明:这种方法是可行的、高效的。
关键词:模糊神经网络, 数据融合, 目标识别
Abstract:FNN was implied target recognition in submarine with single sensor,Data fusion was used in target recognition with multiple sensors. The method which was supported by the result of simulation was high efficient.
Keywords: fuzzy neural network;data fusion;target recognition
