路由选择的一种新遗传算法
消耗积分:3 | 格式:rar | 大小:216 | 2009-05-28
分享资料个
提出了应用于QoS路由选择的一种新遗传算法,该算法给出了基于跳数优先原则的初始种群生成办法,以及邻近交叉和前向变异两个关键算子。算法的主要优点表现为初始种群生成独立于网络拓扑的度量参数,交叉产生了多样性新个体,以及变异有效抑制算法退化等。对随机生成的不同规模的网络拓扑结构进行仿真,结果表明该算法是有效的。The most problems of multi-constrained QoS routing are NP-completeness. In this paper, a novel genetic algorithm is given which is applied to QoS routing. The principle of hop-prior is presented to generate an initial population. Simultaneously, two operators of vicinity crossover and forward mutation are brought forward. The primary advantages of this algorithm are shown as below: the population initialization is independent on the metrics in a network, the new personals born of crossover are diversified, and mutation depresses the algorithm devolutions effectively. At last, the simulations on differ-scale networks randomly created demonstrate that this algorithm is effective.
评论(0)
发评论
下载排行榜
