This application provides an analysis of the PCM1710’s output spectrum and data from actual use. In addition, a sample design of a post-low-pass filter for the PCM1710 and test measurements are presented for the user’s reference. The PCM1710 incorporates a low-pass filter to remove oversampled high-frequency spectrum noise. The equivalent circuit of this internal low-pass filter is shown in Figure 1.
