菱形结构晶体管OPA660
消耗积分:3 | 格式:rar | 大小:85 | 2009-06-05
胡秋阳
分享资料个
The monolithic integrated circuit OPA660 uses the Diamond
structure to act as an ideal transistor. However, this
circuit has the advantage that it avoids the biasing circuits
and eliminates the need for an offset voltage compensation
network. With this element, peripheral components are reduced
to the essential minimum. Using the DC-coupled
wideband voltage amplifier and buffer, conventional and
new circuit designs of the OPA660 can be compared with
each other.
评论(0)
发评论
下载排行榜
