基于透视逆变换由图像点反求空间坐标
消耗积分:5 | 格式:rar | 大小:124 | 2009-06-09
路过秋天
分享资料个
三维重构理论与技术是计算机视觉最重要的热点问题之一,基于单幅图像的三维重构
由于缺乏足够的几何信息而难以达到预期效果。本文针对大部分物体所具有的对称性特征,提出利用假想对称平面,基于透视逆变换原理,由人工交互指定已知三对对称点的图像坐标和空间坐标确定透视变换矩阵,继而反求物体表面特征点的空间位置,再利用UG 软件实现三维模型的重建。
关键字:对称物体,视点位置,透视逆变换,反求3D 坐标
Inverse of 3D from Image Point Based On Projection Inverse Transformation YU Chang-hui, YU Yong-yan (Huaiyin Institute of Technology, Jiangsu Huaian 223003) Abstract: The theories and techniques of 3D Reconstruction are one of the most important problems in the computer vision, Single-image-based 3D Reconstruction because of lacking enough several informations but hard attain to expect the result. This paper aims at the symmetry characteristic of most objects, putting forward make use of to imagine the symmetry flat surface according to Projection Inverse Transformation principle, handing over from the artificial to specify with each other to have already known that three picture that rightnesses are a little bit symmetries sit the mark and spaces to sit to mark the Projection Inverse Transformation matrix, Inverse the 3D position that the object surface characteristic order, then make use of the software of UG to carry out 3D models.
Keywords: Symmetrical object,View position,Projection Inverse Transformation,Inverse of 3D
评论(0)
发评论
下载排行榜
