CS5101后调整器特性说明及利用CS5101和CS3842
消耗积分:3 | 格式:rar | 大小:218 | 2009-06-10
goodmbby
分享资料个
In Switch Mode Power Supplies (SMPS) a transformer
provides isolation between the primary source and the
secondary load(s). If the SMPS controller is located on the
primary side of the transformer, the feedback voltage
from the secondary is fed back to the primary side
through another isolation barrier, usually an opto coupler.
Tight output regulation is more difficult in multiple output
power supplies. The following are the most popular
techniques.
评论(0)
发评论
下载排行榜
