异步电动机的转矩转速曲线是异步电动机的一项重要特性,本文提出了一种利用JCZ型智能转矩转速传感器来实时测量电动机转矩和转速的方法,并且用PCL711B 数据采集卡同 步采集电机的端电压来对转矩进行修正。在VB 中引用Matrix 库函数对数据进行处理,最后拟合得到M - S 特性曲线。试验结果表明,这种拟合曲线的方法是切实可行的。 关键词 异步电动机 JCZ型智能转矩转速传感器 VB 转矩转速特性曲线 Abstract The M2S curve of asynchronous motor is very important to motor. This paper present s a new way to test torque and speed of motor real2time with JCZ intelli2 gent torque2speed sensor. At the same time we sample end2voltage of motor with PCL711B. We can draw the M2S curve with Mat rix in MATLAB. The result shows that this way is feasible. Key words Asynchronous motor , JCZ intelligent torque2speed sensor , VB , M2S curve.
